Hi, My horn wont work! I have checked all connections behind the wheel they are ok, wiring into the horn looks fine but it keeps blowing the fuse. I have heard it work shortly befor eit blows the fuse. Any ideas would be great as I dont really want to buy a new one if it is something obvious.:confused:
Welcome to the forum :)
The first bit of advice I would give you is that the search function is your friend T:
the horns often have issues, sometimes due to the placement in the wheel arch. May just need replacing...
defo search on here though - plenty of stuff about horns!
My early van had the same problems turned out there was no relay fitted, check it just in case
Thanks for the advice, finally found the horn in the wheel arch, it had suffered over the years! Got a second hand one from the scrappie and now I am fully horned!A:
