Just had to get the T4 MOTd.
It failed due to a rear coil spring which had broken on the bottom coil... and the handbrake cable under the centre of the van is pretty threadbare (as in half thickness) and has some strands hanging off.
Went to GSF but they dont have the right bit
so I ended up getting a new cable section that makes the Y shape to each rear wheel (from GSF) seeing as I will be redoing the mechanism anyway.
But I now need to buy the main cable section that runs underneath the van.
ive got it down as PN 701 711 476 - is there anywhere else that sells them except VW? and does anyone have an idea of price?
it works perfectly which is a real PITA as I have heard they can be a PITA to setup right I:
