Cheers lloyd13 I appreciate that. There are certain aspects in the van which I am not entirely happy with but I have been told I will grow to love them as quirks of the van ie she has told me to leave them alone!! LOL
Right for a first timer...screws... I went for the drywall screws after much deliberation. 25mm x 3.5mm in black. I though these may hide nicely with the anthracite carpet lining.
I don't have many power tools. I have a donated drill, a donated jigsaw and that about summed it up. I trotted off to B&Q again, and got myself some new blades for the jigsaw and treated myself to a rechargeable cordless screwdriver due to the amount of screwing I was to be doing.
I suffered a lot getting the screws through the metal panel. I tried all the ideas previously mentioned, including drilling (and snapping drill bits) pre screwing holes then lining the ply holes up, this sounds ok till half the panel is attached to the wall and you cant see the holes.
Again I resorted to violence, using a girt big hammer, I screwed the screw in past the ply till it lifted off the metal then smacked it till it went through, not the best idea but it did work for most of them. The rest just either bent snapped or went blunt!
Now most of the panels went up ok, on the second day of fitting my guchi screwdriver went flat so I recharged it, when going to use it again it spun round fine yet as soon as pressure was put on it it died. So I went back to B&Q for a refund and decided to spend out and buy a 'decent' cordless drill / driver combo. I have to say I wish I had listened to the other half who said the previous day to go and get one but I mustered through.
Only having the roof left to do was the only down side of welding my new weapon.
I think some of my struggle with the panels was going through the overlap of carpet on the metal work as the screw does catch on it and twist around it preventing it going in. Still it was too late to rectify this now.
Roof panels do need a second person to assist in holding the panels up to the roof in the right position while the other has to quickly get a screw in to hold the panel up before the other persons arms can't stay up any longer.
I had a number of issues even with the new driver getting through certain parts of the paneling, whether it was too thick or an area that had been welded I don't know but I had to change the position of screws as and when they failed to go through.
I used the original roof paneling which I cut down slightly to suit my lighting plans which I will show later. The holes were trimmed off and any remaining holes were gaffa taped over, they didn't show through the carpet so I was happy. As for the OE interior lights I cut a template out and filled the holes and gaffa taped around on both sides which worked a treat.
