I get this fault on my 1999 T4 on VCS. Engine runs rough, pickup is slow, idle surges, fuel consumption is high so I think it's correct. It appears that the pressure sensor is located in the ECU. I've searched the forum but cannot see if this is correct. There's a small diameter pipe running from the inlet manifold to the top of the firewall/bulkhead where I think the ECU must be located. Can anyone confirm that the manifold pressure sensor is inside the ECU?
The fault code is: 00519 - Intake Manifold Pressure Sensor (G71)
03-00 - No Signal
I've checked the pipe and there are no leaks.
Its a 2.0L AAC engine with a Tickfords gas conversion (no MAF). Fault is the same on petrol or gas, pickup is slightly worse on gas as you would expect
I'm hoping that I can avoid replacing the ECU, guessing that it will be expensive?
03-00 - No Signal
