1993 54,000 miles, 2.0 Petrol.
I wonder if anyone can please help?
Problem: When engine is warm it cuts out, sometimes for just a second, other times a change in throttle position or a gear change and power is back again, mostly happens going up hill (sometimes on flat) and normally on light throttle openings.
Tried so far, fuel filter, leads, cap and rotor, Plugs only done 4,000 miles but are three years old, cleaned and all look fine... new coil pack and module, temp sensor (4 wire one).
Have inspected throttle body and all ok, ran with fuel cap off in case a vacuum was being caused.
Thinking Crank Position Sensor? But wouldn't that just completly shut down when it fails? Or ECU? Really can't think of anything else?
Hoping someone can help, thanks in advance, Maf
