2.4 AAB (1997)
Alternator belt clatters very loudly between the bottom pulley and the water pump:-
Does not do it at constant revs or at idle but sounds bloody awful on 1st turn of the key, when turning the engine off & also as the revs drop just before settling to idle?
I’ve had the van 3 months & I think it’s always done it, hard to be sure as weve only done 600 miles in that time.
Tensioner plastic wheel is new & the tensioner arm feels OK, by that I mean I can’t feel any sideways play in it & the spring feels like it has significant resistance, I don’t think any rattles or noise is coming from the tensioner itself either.
Water pump & alternator pulleys run freely & I can’t feel any sideways slack.
Will I have to replace the tensioner to eliminate it or is there anything else worth checking?
How do I separate the arm from the tensioner? There are two allen screws that retain the tensioner into the cast bracket plus one in the centre of the tensioner itself, I have removed the centre screw but the arm won’t budge & I’m sure I can’t remove the tensioner without 1st removing the arm?
Any advice appreciated.
