Hi. Still got the dreaded leak from the spindle seal as still not sure if i can do it myself. Had a look at the pump yesterday and after comparing it to the How To on here, my pump looks a bit different. It's got a round plastic cap with with a wire coming out covering the throttle shaft. Guessing this has to be removed first i took it off for a look underneath. I could then see the end of the throttle spindle with the groove cut in the top and the plastic cap had two sections which lined up with a part connected to the throttle spindle so at a guess i woud say this is some kind of throttle position sensor. Anyone know any different and if i risk screwing up if i remove it. it used to be an automatic but has been converted to manual so maybe this is somrthing to do with the auto box. confused.:*
