Hi I've just replaced the 2 mid sections of the exhaust on the van (new mounts too) all good but noticed on the start of the back box section I.E before the silencer close to joint with next section. That there is a hook mount the same as the one on the previous section used to mount the rubber donut type mount.
The body does have any kind of bracket on it either, exhaust seems well supported without it and having looked at various diagrams online I can't get a straight answer as to whether there should be a mount there, would like to know what the bracket on body is (if exists) cheers :-D
Also rear springs are looking a bit rough, they're 35/40mm drop heavy duty ones, any suggestions for good quality replacements of the same drop/load rating or maybe another 10mm drop on so 50mm ish. Cheers (again) !
