I have a 2.4d which have the gearbox completely gone and my shop is rebuilding it. I would like to know if any of you knows a cheap place where is possible to buy the gears, bearings etc...., better if it is online as I live in Italy.
I know that there is a 5th group buy but I need quite a few more parts.
Thank you very much,
Matteo
Unfortunately to my knowlege the gears are only available from VW but bearings and seals can be purchased from anywhere if you can read the dimensions off the seals and measure the bearings. Planet gearsets are about £150 on thier own in the UK so be careful the cost doesn't run away.
Thank you very much for your answer.
In the ETKA there are the dimensions of the bearings so these are not a problem, I was looking for the gears because here in Italy are around 300€, so maybe more expensive than in UK.
Ciao,
Matteo
