Hi all,
I'm putting in a new water pump pn my 2.4d and there is a plastic washer that came off the old one, but can't find where it's supposed to go when putting the new one on..:confused:
Can anyone help me out?I:
Its number 11 on the pic..
Cheers,
If it's number 11 in the picture then it must go in the block before the pump surely :*.
Does it support the end of the pump spindle or something?
By the look of the drawing it will either sit on the vanes of the pump or directly in the casting.
It probably has no other function but to reduce the hole in the casting.
I know what you mean, but the casting is way too big and there is no where for it to go on the water pump..
Unless the washer is for something else? Its a plastic washer with 3 little lugs on the outside... can anyone think where it might go?:*
Post a pic up of the internal end of your water pump and the plastic washer if you can, maybe another pair of eyes seeing it could help.
I did mine (2.4 AAB) in the summer and didn't see anything like that, just took old pump out and popped new one in.
