Ok I'm up now, and (slightly) more sober T:
Please see below, I did mine earlier this month without too much bother...
Voltage regulator changed for a new VW (Bosch) one from TPS Preston. ÂŁ80 odd inc VAT.
Changed on the drive, without the front of the van coming off.
disconnect battery - goosed anyway
Front engine mount off
Disconnect a/c unit and jiggle out of the way
alternator unbolted and PS pump removed for easier access
not enough room to remove the alternator but enough space to move it around and disconnect / reconnect the voltage regulator.
Airbag warning light, plus other voltage related fault codes reset.
All good, not found anything that doesn't work yet.
think I got off lightly.
Let me know if you need any more detail
