1 - 20 of 112 Posts
Since just before Christmas my engine has developed a fault.
The van cut out in the City and the AA came and restarted it (easy start) and followed me home (40 miles away).
Once home he put his diagnostic machine on it and found a camshaft sensor fault.
This fault has always been on my engine since I got it 3 years ago and has ran 32,000 miles without issue, so this was not the fault.
He gave the diagnosis as "fuel related"!
It kept cutting out so I was told to check the tandem pump (which was rebuilt 6 months prior) I found the central seal had blown, which was my fault for installing it in the wrong way round!
This has leaked oil into the fuel system, so I hoping had found the fault drained the oil contaminated fuel changed the fuel filter and filled with fresh fuel.
The problem persisted so I was told to replace the injector loom as this is a common issue.This was a bit of a pain of the job (front end off!) and after not getting the connecting plug seated properly and having to remove it twice.
On testing again it will idle for 30 minutes and checking on VCDS/VAGCOM the deviation value on injector 4 goes way out and then begins to misfire and stall and will take ages for it to restart again.
Strangely it has now been left waiting for the next stage for over a month which it has been started every day to move and never had issues
This has now been diagnosed as a faulty injector/s so I have purchased some replacements and after waiting for over a month now I am going to attempt replacing myself as all the mechanics I speak to are shying away from working on this engine.
What specialist tools do I need to remove the injectors and to realign and set them once replaced? How do I turn the engine over as their is no crankshaft pulley to turn as a normal cengine?
Super Moderator
As said in your other post you need to check compression on all cylinders and also check block 004 in engine using vcds first and see what the cam timing is. Even though it's been fine for 32k the camwas out then and may have slipped and put the timing out further. You possibly haven't checked fuel pressure at idle like was suggested but have changed stuff which on line mechanics have suggested. The law of averages is eventually will find the problem but at what cost? Injector deviation goes out because the ecu is trying to stop the engine running away and keeps the rev's under control, it could be low compression caused by cylinder bore wear, vavles no seating correctly or one of the followers are damaged. If the front was off to do an injector loom which in my opinion isn't as unreliable as the 1.9 pd as the loom is not submerged in the oil. There was other stuff you could have checked whilst in there.
Sorry festa I am just doing what other local so called mechanics nearby have advised.
But I believe they have even less knowledge than even I have and have only tackled the PD1.9D.
I have no way of checking the compression or the fuel pressure but luckily the front end is still removed so I can delve further if you could advise?
Should I get a compression tester and fuel pressure guage and if so where do I purchase these and how do I use them?
What should the cam timing be on measuring block 004?
I agree about the injector loom as I tested this on removal and could find no fault.
Lastly it seems very strange that this will idle for 30 minutes and go way off on injector 4 then stall and refuse to start. But am I reading to far ahead?
I am really struggling as their are no reliable mechanics locally that have dealt with this type of engines and the ones that say they have are telling me lies.
I didn't want to have to do this myself as I realise the complexities of this beast and understand that if I do something it is going to leave this grounded for quiet some time.
SC
Super Moderator
First things first ...start the van and plug in vcds, go to engine 02 and then go to measuring blocks. Go to measuring block 004 and post up here the picture if you can get a screen shot. It will give an idea of injection timing and camshaft timing. An m10 pressure gauge to 10 bar...there is a test point on the tandum pump which requires an m6 allen ley to remove the plug. Place the gauge in the hole and start the van. Get a reading at idle and one at above 2000 rpm and post back on here.
OK here goes at tickover on measuring block 004 It reads:
798RPM 7.4BTDC Ignition Timing 7.1o KW Idle stabilzation -2.5oKW Idle stabilzation
I haven't managed to get a reading for the pump as I do not have a pressure tester yet.
Are you sure this couldn't be an injector issue as when previously tested the deviation value on number 4 goes way off after half an hour on tickover and then stalls?
SC
Super Moderator
I would say the timing is to far retarded at idle...it should be around 5-5.5deg rising by 6deg every 1000rpm
Just checked this myself as my mechanic reckons he tested it as he had revved it up!
These readings are from cold.
If you leave it ticking over for 30 minutes no 4 goes over 4.0 and then the engine cuts out.
Engine starts as good as ever and ticks over for 30 minutes perfectly.
SC
Discussion Starter · #11 ·
Festa I'm pulling the injectors in the morning as I desperately need it back for the weekend. Are these values within the ones stated. This is it from cold.
SC
Super Moderator
Number 4 is not 4.0mg/str but 0.4mg/str and I can't see much wrong with them but then it maybe a temperature thing where the injection quality may change . If you have 2.99mg/str you have more of a problem
Discussion Starter · #13 ·
festa thanks for your reply.
Number 4 only goes way of after 30 minutes of idling as you can see it is OK when first started.
I am thinking either a sealing issue or a fault internally on the injector.
SC
I would have thought if it was just injector 4 or it's wiring was at fault when hot, the engine would run very lumpy on 4 cylinders, but not stall? The fact it stalls and doesn't restart until cold, to me indicates fuel starvation. As said above, tandem pump pressure test needs to be done to confirm or rule this out.
I assume no codes flag up after the stall events? ie cam sensor, crank sensor, no correlation, injector fault. Have you trawled all the measuring blocks to see if any values make no sense when hot, particularly temperatures?
Discussion Starter · #15 ·
Well we have one and four injector removed.
Injector bores look perfect and seals were all intact.
So I am hoping more on internal injector fault.
Rather on replacing all 5 I have opted to change 1 and 4 as 4 was doing stupid things when left running and 1 did get higher than all the rest.
I am thinking if not showing any faults 2,3 and 5 may as well be left alone.
Once it ticks over for 30 minutes as said before number 4 goes way high on the deviation values and the engine stalls and takes a while to restart (maybe cools down).
I have been told by a few people if the deviation goes over 3-3.5 the ECU will turn the engine off so as not to damage itself.
No other codes or faults show on the measuring blocks other than the camshaft sensor issue (not plugged in) which it has had since I bought the vehicle.
SC
Discussion Starter · #16 ·
Well it runs....but it did before!?
It took a couple of times but I was expecting that as the two injectors replaced fill with fuel.
Gonna test tomorrow and see if it cuts out, and if it doesn't i'll put it back together and see how it runs over the weekend.
SC
Discussion Starter · #17 ·
Well I have checked it and all the injector values and all are stable.
I then put all the front end on and took it for a blast.
80 milese in and it is runing sweet.
Let's hope that's the last of it.
SC
Discussion Starter · #18 ·
Now over 350 miles and it's running great.
Still panicing when coming to a halt and worrying that the engine will die. But no problems so far.
I think the issue with this was a fault either mechanically or electrical with injector 4 as all seals and fixings looked in perfect condition.
It seems to be running a lot smoother and a bit more economical.
Just need to get on with the jobs it needed doing at Christmas time, such as serviced and nearside front wheel bearing.
Thanks for all the help and advice on this one.
SC
Discussion Starter · #19 ·
Sorry to bring an old thread up, but it's the same fault all over again 12 months later.
Over the last couple of months occasionally the old 2.5 has taken a little longer to fire up!!!!
Well this evening I got in to go home (only 1.3 miles away) it turned over but did not fire up.
So I went over and got the work van and jump started it which it did straight away.
I thought I will just grab a spare battery and the jump leads as it is not doing many miles during the week and most of it in darkness so the battery will not be getting much of a charge.
Also whilst in there I left it running and did a VCDS scan on it just in case their were any other faults logged.
Well whilst it was idling and scanning it started to run lumpy and eventually stalled and would not start again even with a freshly charged battery.
This is exactly what happened this time last year before I changed injectors 4 and 1.
I noted on the log this time that it says:-
000773 - Cylinder 5
P0305 - 000 Misfire Detected
Is this a sign that Injector 5 has now died ?
Due to it not starting I cannot check the deviation values whilst running so cannot check them. But the way it stalled is the exact same.
I had to go home so will resume fight in the morning...
SC
1 - 20 of 112 Posts
