Brethren ... I’m looking for advice. 2002 2.5TDI Caravelle. Last week went to pull away from a standing start and it felt like it was going to stall, it did ... and then the gear stick suddenly when sloppy ... so I discovered on here that it was likely to be the gear selector bushes/balls. Investigated this and the bush holding the small ball on the T bar was mashed and the T bar was all over the place. A 10 minute job I had read by all accounts and only £15 for all the balls and bushes. BUT because it’s a caravelle, with heating pipes for the passenger side going over the top of the T Bar, it’s taken 2 f’ing days to take it apart and put it back together again. Trouble is now it's almost impossible to pull away in first unless I ride the clutch. So question is, is there an adjustment to make on the T bar (I don’t think there can be) or is the clutch/slave cylinder/master cylinder knackered. If it is the clutch is this what led to the Bush finally falling apart??
Also if a new clutch is required ... how much and where can I get this done - I'm in Reading, Berkshire
Helppppppppppp!
Helppppppppppp!
