We've just acquired a 2003 T4 2.5 tdi, sometimes the doors lock themselves without warning about thirty seconds after unlocking and putting key in ignition, it locked up once just after someone got out having left the key in, anyone had this problem before?
i only get this problem when the interior light switch doesnt activate the light. they lock themselves after about 40 seconds if you dont open a door but i never heard of one locking itself with the ignition on :*
Hi, thanks for that, I beleive you're correct, neither front door works the courtesy light, the side door does work it and if you open side door it doesn't relock itself, now I need to find out why courtesy light wont work with cab doors! Dave.A:
Try unscrewing the activation switch in the bodywork, clean the contacts and earth and replace. Remember to keep hold of the wire and not let it go back into the cavity. Worth a try.
