Appear to have pressure in the expansion tank once hot, however , no visible coolant in oil and no visible oil in the coolant.
Having no starting issues, but do have white smoke on start ( strong diesel smell, clears on warm up )
Vans holding at 90 with no overheating.
Coolant dropping ever so slightly after a few hundred miles.
Thermostat appears to be opening with both bottom and top feeds warm once running for a bit.
Heaters are blowing when warmed up , very hot!
Could there be anything else creating pressure build up before assuming worst case scenario of a Head leak!’
Water appears to be circulating ok.
2.5 Tdi (AJT)
Anybody experienced anything similar?
If head gasket, what kind of price should I be looking to expect for a repair and any repair garages recommended?
