Afternoon folks.
I've just put the engine back into my '97 Carvavelle post clutch and dmf change to resolve a leaking slave cylinder.
It refuses to fire!
I've research a lot of threads on here - most associate the problem with the glow plug light not coming on and a broken earth return from the ecu across the top of the engine & the infamous 109 relay starting problems (my black and white) wire has been spliced already lol!)
I've fairly much ruled that out - my glow plug lights up & and goes out again, but does flash after a minute or two with ign on - indicating a fauklt I understand.
I assume I've a broken wire in a loom somewhere or plug not quite home! pushed and pulled & disturbed a fair bit / most of the wiring :-(
VCDS lite wouldn't connect - but that was the same prior to the job. Generic Autel fault reader didn't show any issues.
I've got a proper ross tech cable and VCDS works fine???
Throws up the following faults - I know some of them are caused by cranking over, so more interested in thoughts about the N146 & the data wiring for the immobiliser?? Any advise or previous experience appreciated. I didn't touch the timing etc, both belts are intact - that's my next job - didn't want todo too much without a working vcds - which I now have.
VCDS Version: Release 15.7.4 Running on Windows 10 x64
Data version: 20160216
www.Ross-Tech.com
Friday,20,May,2016,13:44:06:53138
Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
Address 01: Engine Labels: 074-906-021-ACV.lbl
Part No: 074 906 021 L
Component: 2,5l R5 EDC 00SG 1450
Coding: 00002
4 Faults Found:
01268 - Quantity Adjuster (N146)
35-00 - -
27-00 - Implausible Signal
00765 - Modulating Piston Movement Sensor (G149)
35-00 - -
01269 - Commencement of Injection Valve (N108)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 25: Immobilizer Labels: 1H0-953-257.lbl
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0V5222191 V00
1 Fault Found:
00546 - Data wiring faulty
Thanks in advance!!!!
It refuses to fire!
www.Ross-Tech.com
Coding: 00002
4 Faults Found:
35-00 - -
35-00 - -
Readiness: N/A
1 Fault Found:
