1 - 16 of 16 Posts
1. will a complete fuse-box from a 1998 caravelle 2.5 tdi, fit into my, year 2000,t4,2.5 tdi,ajt ?
2. how easy is it to swap them over.?
thanks.
Very easy as they are identical. Let the fuse box hang by the wires and mark them or move one wire at a time over to the new fuse box.
indian,
thank you for your reply,
that,s good news,will order it now.
£40.00 on flee-bay for complete fuse box./ relay,s.
Full of Cr*p....
Just note, not ALL the relays may be there.....depends upon spec.....just swap your existing relays into the new one if some are missing.
Same goes for the fuses.......
Wire-by-wire change as Indian says.
Hehe....TWO quick questions, TWO quick answers........but allow a few HOURS to do the job!LOL:
Remember that the wires are locked in place by a sliding bar. You have to unlock before pulling out the plugs from behind. Otherwise you can damage something.
This base for the fuses and relays are used in all VWs up to 2003 at least. I got one from a Golf for my VR6.
thanks all for your input, appreciated.
hybrid800, £40 seems to be the going rate, other 1 was £46 with no relays.
time to clear your shed,i think,T:
I pulled one off from a Golf 3.
apart from the t4, I have a 1987 mk2 Golf that's tdi converted, a 1989 B3 Passat estate that's tdi converted and a 1996 B4 Passat tdi estate (factory origonalT: )...
and a few other carsI:
I can't stop 'fiddlin..........
Rich.
Discussion Starter #14
update==
the fuse box is lost in the post, have the tracking number.
have date & time & location. nothing since it was posted on 03/07/18.
the sender has been very helpful and offered me a refund. and checked things his end.
the post office were a waste of time, wait 15 days then report it missing.
how can a package go in the front door,get handed over,track number issued, and not be traced ?
HYBRID800--might be sending you a PM.
heading for france/spain on 20th, need to get this fixed before we go.:confused:
update==
Get the refundT:
message away, I've a few spare, can put your name on one:cool:
Rich.
1 - 16 of 16 Posts
