Hi There recently bought a caravelle with the dreaded auto box! Has gone in to default and bringing up
time faults all the time will not clear or re cal with vag com.
I want to convert it to manual (i am a mechanic)
just wondering what gearbox code i need for my engine?
Engine code AUF
Current gearbox code auto is EQG
Just need a manual gearbox code please?
cheers Ed
Discussion Starter · #2 ·
Just to update all you guys,
My engine is an AFU and that will fit a EWB manual gearbox with slight modification of the flywheel
to marry up with the crank, also diffrent starter motors, nearly all done, will update with costings and details if helps anyone....!
cheers Ed
Its hard to tell if the torque converter is any good a bit to much work to just try it!!, nearly finished the conversion, will let you know details
hi eddielam
if its not too much trouble can you give me a comprehensive run down of all the parts you need to do this convertion, codes etc as i am looking at doing the same job but i want to source all the parts i need before i start it. Also what is the alteration you have to do to the flywheel. mine is a 2.5 petrol velle 1999 lwb. Cheers for any help.
