hi guys
As above says does anyone have good solid advice on how to set it correctly,,if its anything like dialing in the cams on a 1200 bandit motor then if done properly it should
start/perform & run spot on with better MPG no lag Eg: flat spots & a good diesel knock,,not from the bottom end either;),,many thanks
RickT:
