This topic seems to have been very well covered on here but I can't seem to find the info Im looking for.
I have just bought a 2002 2.5 tdi, it has 130K on the clock and the belt was changed at 90k. The service book does not seem to indicate that the water pump was changed at the same time. I understand the interval for the belt is around 60k so theoretically there is still life in it yet. However the VW service history stops at 90k so I have no record of what has been done since that time.
Im looking to get it changed to be safe and Im getting quotes between £500-£600. Although virtually everyone one here says change the water pump at the same time, some of the garages are saying that the cam belt on the 2.5tdi does not run the water pump and therefore replacing the pump is not necessary and seemed to say that the pump was right in the heart of the engine and replacing it was not needed and more difficult.
Im looking to find out firstly whether the water pump is run by the cambelt on this engine? and secondly what are the potential consequences of the water pump failing, is it as severe as the cam belt failing?
any help would be appreciated
