1 - 19 of 19 Posts
2006 Caravelle SE 2.5 AXD
Hi guys,
I'm Ben from Wolverhampton - thought I'd start a build thread on my new to me 2006 Caravelle in Ravenna Blue:
188795
This conversion will be slightly different to the usual layouts, the van is ex-motability and has a wheelchair ramp at the rear, along with some swivel out extra seats at the back:
188796
188797
188798
The van had 85k miles on when I picked it up, which seemed pretty low to me. Its in reasonable condition, but I've got a list of jobs already:
Replace both bottom rollers on sliding doors - 1x done
Respray front bumper/ sections of front bumper
Fix rear central bumper (loose and damaged after 14 years)
Heater control has the 12-3 o'clock cable issue
Tailgate gas struts replacement
Two new front tyres
Strip out rear seats
Plan interior!
Sliding windows slight leak
Tandem pump slight oil leak (but no evidence of leaving oil spots when parked... no undertray fitted)
Find out what trim the seats are (does anyone know?)
Find a T5 VW bike rack or fit the bikes on the roof
188800
188801
The triple bench seat and the swivel disability seats were quite heavy! The rear trims have been cut away and an L shape steel bracket has been welded onto the wheelarch. This creates a handy mounting point for my plan of U shaped seating, with a pull out kitchen to the rear. I've found quite a few handy mounting points from the conversion already. I am looking into a rear tailgate driveaway awning. Current plan is to shorten the wheelchair ramp in line with the standard floor, and build up the recess in the floor to level it out. Probably use ramp area for storage or pull out drawer to the rear.
Hopefully we'll be free to travel around this summer, so hoping to get the van to a usable condition by May.
Wish me luck
Ben
Welcome Ben!
I know I've posted on your other thread when you purchased the van, glad to see one more local to me anyway! So if I'm out in the van in the Wolverhampton area then I'll look out for you馃槤 You'll probably see someone frantically waving at you!馃槀
Looks like you've got a large list to keep yourself occupied so far, no doubt that will get bigger as time goes on but looking forward to seeing how you progress!馃憤
Cheers both. Ticked another job off the list last weekend - tailgate gas struts replacement, took all of 2 minutes lol but its all progress.
Very slow progress so far, which I'm blaming on the cold weather and my indecisiveness! I have just swapped insurers from Direct Line to Brentacre, as I didn't think Direct Line would like me removing seats and attempting a day van interior!
Got a long weekend off work coming up, so the angle grinder will be coming out to play on the wheelchair ramp and will also be removing the rear trim panels to free up space. Would like to retain the blinds section of the rear trim though, so will get my thinking cap on.
Have got two camping trips planned in June, so I definitely need to crack on!
Discussion Starter · #5 · (Edited)
Update time:
190046
Ramp now shortened in line with body, inside of ramp lined with flashband and thermawrap.
192671
Caravelle rail covers removed, started ply lining floor to level up. Side trim removed, showing ducting and HVAC.
192672
Hopefully will finish ply lining the floor soon and can begin to work out layout options
192673
192674
Cheers,
Ben
Cheers mate, yeah that was me! I was in a world of my own this morning, wondering whether to do a swamper look on the Caravelle! Really must update this thread with my progress!
I was standing at the griddle having a sandwich on break at work, daydreaming myself and thought I recognised the van then the number plates as well馃槤
Swamper look would look great on the van I think as well.
Discussion Starter · #9 · (Edited)
Update - from this:
192503
To this - new full crash bar, full bumper...
192504
192505
at lake Vyrnwy
192506
Karndean floor laid
192507
Storage area for electrics / leisure battery, making use of the ex-wheelchair space
192508
Making use of cheap tints until I can change the windows for new
192509
Started carpet lining
192510
Taking inspiration from this layout for the build - its from a T25. Aiming for a rear bunk bed area for my son with a 180cm length bed for the wife and I, but quite flexible in that it can be turned into a u shaped seating area too. Will sort a layout diagram to explain!
192512
Discussion Starter · #12 ·
Battled the rain yesterday to try and get some progress. Wheelchair void will be home to the consumer unit, leisure battery, junction boxes etc. Will fit a hinged cover for the rare times I'll have to venture into it.
192665
192666
Discussion Starter · #14 ·
A few more bits:
Plywood interior coming along:
192925
Fitted the hook up point:
From this
192926
To this
192927
Diy spray booth:
192928
192929
Further inspiration from this:
192930
T4 california coach 2.5 tdi 102 -11/1998
very classy this blue. 馃
good job on the layout of the T5馃憦
  • Like
Reactions: cerbera84
Thanks so much for this thread!
I have a shuttle and wanted to know how carpet lined panels would look so this has helped me no end. Have you got a pic of the sliding door panel/door card after carpet lining?
Discussion Starter · #18 ·
Sorry, haven't got round to the sliding door panel yet, debating whether to buy the Kiravans door store or not...
I鈥檝e just noticed your sealing off your pipe work from the hvac.
I鈥檝e had a hell of a time today trying to get the trim off that section of the rear, was it difficult in the end? Am I being a wimp thinking I will snap it if I pull too hard
1 - 19 of 19 Posts
