Evening all,
Just picked up a T5 that has both drivers and passenger electric windows not working, checked fuse under the ashtray, check thermal fuse, both ok, I have two feeds at the switch, but what should happen when the switches are pressed? what out put should I get a live or earth signal ? checked the motor and that works if I power it up from a separate earth and live,
Central locking works off the remote open/close but the central locking doesn't work from unlocking via the drivers door lock,
Both electric mirrors work.
Any help would be much appreciated
Look under the drivers seat, check the wiring for corrosion to the module there. Red/blue wire feeds the power to it, you'll have to lift up the matting and have a good look.
Does the electric window switch send power to the window motor or does it send an earth? is it possible to power the motor up by bypassing the switch?
