Hi all, I've got a 2011 2.0 4 motion and it keeps getting an intermittent engine warning on dash, code reader reveals a
p0016 camshaft position camshaft- position correlation bank 1 sensor a
Which I suspect is a timing issue?
Anyone had this?
Hi, just curious to what symptoms you are getting from this error code?
Any lumpy fuelling/ rough idling issues?
My t5.1 2.0 tdi is surging from idle with erratci fuel pressure issues and wondered if this code/cam timing is the cause??
Cheers, Phil
Pendle Performance Main Agent
Anyone had this?
Last time we had this fault was because the sensor had failed, new one in and all good since.
