Hi anyone know the easiest way to fit cuddle lights in the footwells, i would like them to come on with headlights, whats the easiest way please, anyone know colours of wires to follow, Thanks.
On a large plug type headlight switch you can take it off Pin 15 (MFSW fitting guide) as per this guide.
Before you do anything i would pull the switch out and get a Volt meter to test the pin so when you switch on the lights it should provide you with a feed.
