VW T5 T2815K Miles, 84PS, 4 Berth campervan, New Conversion
VW T5 2.0TDi 84PS Campervan With M1 pull tested RIB Altair seating/bed system
12 month warranty on conversion
Remainder of 3 year VW Dealership warranty (Sept 2016)
15,000 miles
13 plate
Colour coded Bumpers and mirrors and roof.
£32,500inc vat
Top of the range conversion using the best brands and components. This 4 berth campervan is fitted with an TUV Approved SCA elevating roof system and M1 Certificated RIB Altair Seating System and newly fitted "Tourer Curve"conversion and facilities.
The design is individual and exclusive to Clearcut Conversions - You won't see this design or Stripewood finish any where else.
This comfortable van offers a versatile layout covering a multitude of uses, the vehicle is spacious inside with plenty of loading space at the back but is also small enough to use as a second vehicle to pick the kids up.
The campervan facilities have everything needed for a comfortable trip away including twin gas hob (gas certificated). 240v electrics and Power Management System (Certificated), on-board water, fridge, LED lighting and leisure battery system with split charging, as well as plenty of storage.
The top of the range RIB Altair seating system benefits from integral, extending headrests and seat slider mechanism allowing a large loading space behind the seat.
Conversion Specification
SCA - TUV approved roof and roof bed - fully fitted and trimmed. integral mattress to roof bed with air-assisted lift, to allow maximum headspace.
Fridge - 50l Waeco CR-5012v compressor with Ice-box and battery protection
Sink - (With external outlet) – Stainless steel smev sink, with darkened glass protective lid.
Hob - Stainless steel Smev twin hob with darkened glass protective lid and 904 gas regulator.
Water - 20L, In-line submersible pump, external outlet
12v micro-switched tap.
Electric hook-up - With flush external power inlet. Built in RCD with 2 three pin socket and 15m cable.
Power distribution unit - Offering 240 to 12v power inversion, split relay alternator charging and 240v, 18 amp mains battery charging, three fused power outlets and battery condition monitor.
Storage – plenty of storage space both for food and clothing, including a corner closet.
Tambour door access throughout.
RIB Altair seating system 112cm width, integral headrests, Integral shoulder belts, Seat Slider mechanism, M1 Certificated Design.
Underseat storage tray on bearing runners for maximum use of space.
12mm hard flooring with non-slip vinyl covering.
12v power outlet
12v LED low power light
2 x 85 amp leisure batteries with intelligent, voltage sensing split relay charging.
Stow-a-way table - rail mounted with hinged leg
Fire extinguisher
