It hasn't been lowered but theyre catching on the back. Tyres are 265/35
Has anyone else had issues or had to make a mod?
With that size tyre you should not have issues, especially if its not lowered. The offset in them wheels must be way off. I had mine lowered 90mm on coils with no rubbing on the back. The front however is a different story
must be then its the inner at the back with has been rubbing with the heat shield and the liner which comes out a bit further at that point.
Sorted the heat shield out with a hammer
Do you know the off set of the wheels. I run 265/35/22 with an off set of 40 I think and they don't rub. They are close but even loaded they don't rub
offset is 40 theyre catching on the inner arch at the back where it comes out towards the back
bend the heat shield up & it will pinch the arch liner in aswell, had a similar issue when I was on 22's T:
only had rubbing on the offside because off the exhaust shield, other side was fine....
