I have the usual setup for 240v supply:
- 240v Electric hook up to RCD unit.
- Inverter from Leisure Battery to RCD Unit
How do I distinguish which 240v should be in use at any one time? What do you lot use? This is no ZIG panel config - all separate bits and pieces.
I use a three pole contactor with the coil energized by mains. Without mains the inverter supplies power through the normally closed contacts and when mains is connected the contactor energises and switches over to the mains.
