Hi there,
I've scoured the previous threads on a similar subject but cannot find an answer.
I have recently had a part conversion and had a leisure battery installed with a split charger and 240v hook up. I have a USB and internal lights running from the leisure battery. There are also x2 3 pin 240v plug sockets. I have only recently learnt that these only function when the van is hooked up to mains. Is there a possibility of running the 240v plugs from the leisure battery if i run a dual wire from the back of the leisure battery into the plugs? (Through a fuse T
If this is possible, how quickly am i likely to zap the battery? All i want to do is run a low emission kettle or heater of something along those lines?
Thanks in advance,
Thanks in advance,
