I have a bush LED tv DVD combi from Argos. It runs at 20watts so quiet low and has a 5amp fuse. Voltage needed Ac 100-240v. So question is, whilst I'm driving to my destination can I power the tv somehow from the cig lighter hole? Once at site I'll use mains hookup.
I don't have leisure batter or split system. Just a cig lighter and then hook up once stationary at the site. I will however be eventually getting full electrics with split system.
Many thanks roz :0)
I'm no electrician, but if its def 240v then you would have to have an inverter to change the current , i don't think there would be any issues putting a cig lighter plug on the inverter
Many thanks roz :0)
Only if it takes a 12v input. Or you use an inverter.
Just get a TV that uses a wallwart that out puts 12v. Then wire up a voltage regulator to a cig lighter plug. And the regulated 12v to the TV.
Two leads fir the two uses.
Would that work? No it's not 12v on the back of tv. Just a hard wired plug. No transformer like older LCD x
Either would do but go for the first one. The bigger one won't give you anything more for your TV.
