Hi, I have a 2004 (53 plate)T4 based motorhome which has developed a temp gauge fault. It normally reads 90 degrees but sometime it quickly goes all the way to 130 degrees resulting in the temp gauge alarm and red light flashing. I've had it in a VAG garage but they cannot find the fault. The engine is not overheating so it is an electrical problem. They now suspect that it might be a dashboard fault and suggest I look around and try and find a used replacement panel. Does anyone know what the part number would be for this panel? The engine is a 2.5 TDI Thanks.
2004 T5 2.5 174
You are forgiven. :) We get about 3 a week now and no wonder.. Surely this can't be a difficult fix..
Rectangle Font Screenshot Software Parallel
