1 - 17 of 17 Posts
Hi guys I have a query for your vast experiences,
I've got the 3 beeps of death from my 05 T28 2.5 SWb when i flash up the ignition.
No other indication on dash other than battery until starting her up then none.
Had a garage have a look at her and no faults are being output. My top banana mechanic mentioned that it could possibly be a light missing or bulb?
The guy previous to me seems to have removed the interior lights apart from the slider one, could this be it?
Any ideas are welcome!
Pendle Performance Main Agent
Nothing came up on vagcom, it could be low battery level, Ginger said something about a new alternator which wasn't, that should make sense to you. T:
Low levels in coolant beeps three times, but also lights up on the dash.
Is it not just a "test" of the buzzer when the ignition is first switched "ON" ? Mine, a 2005 1.9, always done it from new.
Yeah TH!
I'm guessing you're the other top banana mechanic who worked on my van today. Cheers.
I'll keep an eye on the battery levels and see if I can't get some lights in the back, see if that makes a difference..
Still got that rattle at the rear near side though.
Looks like I'll take off all the panels again and maybe get he wife to hit bits while I listen in the cab.
Ive been getting the same thing:(but broke a record today and got six beeps! noticed I had the parking lights on,the strange thing is I didn't realize I had parking lights(no extra position on light switch)that was the first three beeps the next three were abs/traction light on but that's been on for two weeks but it decided to start beeping at me now.
sorry bud I realize that's of no use to you whatsoever
If you leave the indicator stalk switched to either L/H or R/H positions & then turn the ignition switch OFF, the side lights on the selected side will come ON. T:
Maybe a battery low indicator , mine had been stood up for a few weeks and, when it was first started up , beeped twice, never done it before, but,after taking it out for a longish run, all is now ok so, maybe, the battery wasa bit low
Thanks bud I never knew that and that's what had happenedA:
And yep vagcom is showing low batteryA:
Discussion Starter #13
Nothing yet mate. Going to attack it this weekend.
Along with the door catch, the rattle, the stereo, the soundproofing..... Does it ever end??:*
Mine makes the 3 beeps if I turn the ignition with my seatbelt off - if I put the belt on first and then turn the ignition I get no beeps!
Well done that man. Just tried this on my van & guess what ? .................. it's the same T: You never stop learning :ILU:
Stevey I hope you got yours sorted bud, after 5 monthes of my abs/traction light on I took mine to a new garage and got it sorted within 10mins turned out to de a rubbed wire in the n/ wheel arch no more beeps or orange glow from the dashboard, ive got so used to the beeps and orange lights now its strange to drive.
1 - 17 of 17 Posts
