i have an aaz block which i plan too put an abl head on, my old abl was a three hole and the aaz was two hole ??? is there a bore size issue or compression/clearance issue, tech help please .
Discussion Starter · #2 ·
oops! bump " a little knowledge "
Are you refering to the gasket thickness? If so, there is so little difference in thickness between sizes it really doesn't make alot of difference which you use in the real world.
