1 - 20 of 20 Posts
Hi All,
Been looking at the posts about 312mm brakes can someone please I: make a list up are all car or vans that have 312mm straight bolt on brakes please is my pocks are not very big or deep and working night all the now its getting to be a pane in
the -ss getting to salvage yard around Aldershot big big thanks:mw
Late vr6 t4 and er late vr6 t4. thats all that will bolt on that I know of. with the small mod of drilling out your hubs to accept the larger 18mm bolts that late vr6 brake calipers have. Have a look at my vr6 brakes thread.
hi chappers,yours are bigger arnt they? i think audi tt are 312mm,my standard ones are 280mm so if i want bigger brakes i want the same as chappersA:
Big Thanks
For all the information I will start looking out for the parts
top work gents :cheers :jmpg
Super Moderator
trust me audi tt calipers wont,dont fit i know as i have a set here that dont fit :(
Me and spud are going to be using 313mm black diamond discs kbd1157 and a 4 pot brembo caliper on the exisiting hub. But will post up the details soon as as its all in progress. So full parts list and templates for brackets to follow:)
re ,hi chappers,yours are bigger arnt they? i think audi tt are 312mm,my standard ones are 280mm so if i want bigger brakes i want the same as chappers
Yes mine are 313mm discs. so i guess the 312mm are just the same, the size is so close. but then the hat height might be different? its all a bit complicated. fitting 4 pot brembo's to the same discs sounds like a great idea, but i wonder what size each piston is in them,so you can calulate the braking force difference between the single pot 57mm in mine and stock calipers?
as they are both sliding body calipers its the same as having 2 57mm pistons in each caliper for calculations. so its 28.5 mm radius x 2 which is 57mm again. then pye R sguared etc. which my crappy maths works out to be 10202 square mm approx. what do the 4 pot brembo,s come out at?
Discussion Starter #8
Re: 312 brakes parts update
Hi All
Just a update on Friday spoke to GFS I can get all the calipers from them and disc and pads.Its the carriers I
having a problem with I mite have to go to VW for them :*
thanks biggraham
On a side note; PLEASE do post Partnumbers & such for future reference on order for others to be able to find this through the search function...
Discussion Starter #11
Hi All
I.m going to links part number from ATE CALIPER 313mm PR 1LB and VW,GFS staff can cross ref number ok
ATE FRONT
11.9571-9819.2 / 220469(L) 11.9571-9820.2 / 220470(R)
ATE REAR
24.3384-1717.5 / 240267(L) 24.3384-1718.5 / 240268(R)
VW FRONT
7M3615123 16' ATE LEFT CALIPER
VW RIGHT
7M3615124 " " " "
VW BRAKE CARRIER
7M3615125
VW 313X26 5/112 BRAKE DISC (VENT)
7M361301
VW FRONT BRAKE PADS 16'
7M698151A
BREMBO 313X26 5/112 BRAKE DISC (VENT)
09.979.10
Hope this information helps somecome and remember the big caliper bolts are 18mm not 16mm
thanks for your time Biggraham T:T:
Hi All
ATE FRONT
ATE REAR
VW FRONT
VW RIGHT
7M3615124 " " " "
VW BRAKE CARRIER
7M3615125
7M361301
7M698151A
09.979.10
Regarding the 18mm calipers bolts, would it be possible to sleeve the 16mm bolts? I assume that the bolt centres are the same?
Trying desperately to get hold of two of the brake calliper carriers VW Brake carrier 7M3615125, I've searched online but can't find a supplier. Anyone know were i can get twoT:
1 - 20 of 20 Posts
