3rd time lucky
420 views 4 replies 4 participants last post by  akdaka
#1 ·
I'm newish to t4 ownership and I'm so hooked, my wagon has become my daily.
My question is my van always starts on the third try in the morning with a little smoke, after that it's first time all the time.
Is this normal or should I be looking at sorting it before it becomes something worse.
#3 ·
Is it diesel, if you need to use the cold start handle every morning you have a problem as in this country you never need to use it. If your cranking it over a few times the smoke is most probably the build up of diesel, possibly glowplugs a bit tired or pump timing out a bit.
Sent from my I3312 using Tapatalk
