1st post newbie.I have just brought a t32 and my first job is to sort out the ride height,i want to put h&r lowering springs on.What i need to know is the t32 as standard, higher than the t28/30 and in theory if it is, should the lowering springs lower the van 40mm plus the diffrence between the vans,i hope that makes sence.I have just measured my van and the gap between top of tyre to the arch is approx 130mm:eek:.The van is a factory kombi and will only be used as a car once i sort this terrible harsh suspension out.
Sorry to hijack this thread but can whoever answers mention if it possible to soften this suspension. I know a T28 is a bit too weak for a conversion so is it worth it or will the weight of a conversion test the springs a bit more than an empty Kombi and hence soften the ride?
