Did a 300 mile journey and had to refill when I started the engine the following morning. That distance is down to around 100 miles ?
There is witness of coolant in the area of the header tank (pink residue on surrounding pipe work). System holds pressure fine and I've replaced the header tank cap. No witness of water on the oil dipstick and it never goes above 90 degrees temperature wise. Any ideas would be appreciated. Is it worth changing the header tank as the loss of coolant seems to be in this region (as opposed to water pump or head)
