Hi after opions/advice please
I have been looking around for intercooler kits for my 88hp Ajt
The standard vw 102 type used is quite expensive
There is talk of differing sensors and i dont want to go messing around with all that
I would like to keep the van looking standard
I dont really like the idea of the L200 intercooler and all the related pipe joining and cutting etc that sounds like problems brewing under the bonnet
I am not into cutting out the front for a cheapo ebay generic front mount
What i would like is a top mount using the standard vw mounting points (slightly bigger than the std one ?)
Remove the MaP sensor from the plastic pipe and refit into the side of the intercooler
Remove the black plastic pipe air pipe and the 2 clips
Fit the new intercooler to the existing pipes using the 4 mounts already on my bodyshell
Cut out the soundproofing under the bonnet
Hopefully all fitted in about 30 minutes
Does anyone do such a thing ?
Whats the likely cost ? £350 ???
Sounds fairly easy :no
