Would a 102 gearbox and clutch fit onto a 88 engine until a 102 engine was sourced?? Might be a stupid question but can't find an answer and don't wanna spend a small fortune repair/replacing my gearbox etc to have to get rid when I find a 102 engine!
Cheers Si
Yep 88 and 102 are the same engine just different injectors etc so gearbox will fit, not sure if the shafts are different or not.
HTH
Gavin
Think slave cylinders, and maybe gear linkages are different, haven't a clue about the drive shafts. But if you've got a complete set up then it will just bolt up:)
Drive shafts are the same
Both 02B & 02G boxes will fit ,
02G are alot stronger box
I know I'm digging this up but just wanted to make sure people aren't misslead. The boxes are not a straight swap, I believe there is a few differences that mean quite a bit of work to make it fit. Correct me if I'm wrong someone.
