Hi All,
I have just cut the 12mm ply flooring but i want to raise it on 9mm strips - (the standard forum advise way) T:
Don't really want to buy a full sheet as it is an overkill, if anyone has some spare i'd be much appreciated or if anyone else wants to go halves or 3rds on a sheet to keep cost down? anyone else in the same boat?
here's to hoping... A:
i used my old 9mm floor. i'm taking the rest to the tip tommorrow am. it's not perfect but good enough for flooring support.
i'd be happy to drop it at yours instead of the tip. you'll have to chop it up yourself though.
I used 3 strips of 9mm and 2 of 6 (the two rearmost.)
I have a photo but it's somewhere else atm....
sorry only just got your reply.
This sounds perfect, i'm sure there must be a good enough part out of it which i can use?? Will happily cut it myself.
will send you a PM now
