Ok driving forward and then stop. but bus in reverse and start moving. there is a sharp click noise.
no noises when turning etc. but I am thinking that is will be a CV joint. inner? or.....
Does it do it if your driving along and come off the throttle then accelerate again?
Had a similar problem on mine which I thought was wishbone bushes or drive-shaft area, turned out to be the O/S engine mount was knackerd and it was clanging away when going on/off the power or going from forward to reverse.
