Picked up a MFSW of eBay last week. It <looked> the same as my 2013 sportline wheel but with buttons. I've read every thread on here about fitting a MFSW. Got a VCDS lead. What could go wrong?
Airbag off T: although I noticed that it won't fit the new wheel
Repair lead from pin 9 on the clock spring to pin 15 on the light switch T:
Repair lead from pin 10 to pin 17 on the BCM :confused: that wire is supposed to be lilac/white. On mine it's green/blue :*
But there is a lilac/white a couple of pins along and it's twisted together with a lilac/red just like a data bus would be so I used that. Didn't work:(
Maybe they've changed the colours so I tried pin 17, the green/blue.
Didn't work :(
So I gave up and fitted the original wheel back on. :(
And to top it off I now have a stabilisation control error. According to VCDS it's a faulty steering angle sensor so it looks like I've knackered that along the way too :(
Looks like I'll be calling Hazzydays on Monday
That fault code is quite common after wiring mods and you should be able to delete it.
