1 - 12 of 12 Posts
Umm, hiall am a new comwerto owing a T4 (2002 2.5tdi) an the usual turbo noise has disappeaed laving the van feeling sluggish. s teher a way to service tTurbo or am I lookingat a replacement! Im hoping not!!!
Cheers in advance for your thoughts
Matt
It isn't necessarily the turbo itself buddy. There are a few vacuum/pressure lines that run from the turbo to the N75 solenoid valve. These can perish and leak. Nice cheap and easy fix - buy it by the metre at your local motor factors.
The N75 solenoid valve itself may be knackered - easy fix, but not so cheap unfortunately (approx £80 for a new genuine one).
The N75 solenoid valve itself may be knackered - easy fix, but not so cheap unfortunately (approx £80 for a new genuine one).[/QUOTe
Im not a great mechanic, ill see if I can find one that I can sort this out.....shame no Haynes manual.
Thanksfor teh support, I as pretty ed off earlier..Ihaventhad the van long, Ive already done the timing belt/water pump and had to ge the clutch looked at.
Is there an easy way to check?
Matt
Matt
Ha, just realised that thi site doesnt allow certain words!
Ideally you need a diagnositc program called vagcom that you can use to carry out some checks.
If you're anywhere need Bristol, there's a guy on here called Zmok who you could go and see.
Discussion Starter #8
Hi.
Thanks for that, I am very near Bristol. Ill look Zmok up and ask him for help.
Much appreciated.
Matt
Thanks to ZMOK for an excellent job on sorting out the problem, thankfully it was a broken bracket and nothing more serious but it was enough to disable the poweer from the turbo. Zmok found the problem and fixed it well.
he is well worth a call for South West/Bristol T4ers!
MattT:
1 - 12 of 12 Posts
