Hi all,
I have a VW T4 camper with an ABL engine. 78k well serviced including timing belt. No faults or problems until today....
It hasn't been run for about 2 months the last time it started up it was perfect, warmed up correctly, stable idle, no smoke.
After that I fitted an EGR blanking plate and ran it again to test with no problems.
Its been dry stored with battery disconnected since.
Today: cold start with the choke out, engine ran rough as hell, lumpy idle and HUGE clouds of blue/white smoke that didn't clear. Thinking that maybe it was an oil build up from the turbo I let it warm up, it was still running rough but would rev.
The smoke didn't clear and I was now causing a huge smoke cloud in the street so I shut it off.
My first though was that the turbo oil seals had failed so I stripped off the hose from the turbo outlet to the intake and ran it. It made no difference. I then thought that maybe the turbo had failed on the exhaust side and was blowing oil into the downpipe. I removed the exhaust from the turbo and ran it - same problem with masses of smoke even from cold.
See video below of a cold startup with the turbo elbow outlet removed from the exhaust.
Video on vimeo:
VW T4 ABL smoke
The smoke smells like burning sunflower oil / possibly unburnt diesel.
I'm completely stumped on what could have happened. Nothing has changed since last time it was run.
All help would be gratefully received!!
I'd be checking the cambelt timing I think first but atrange why it would be like that all if a sudden
Timing does seem like the next thing to check.
I checked the cambelt visually. It looked in good condition and had clearly been changed a few years ago. Belt tension was spot on too.
I've only ever seen a cambelt jump once in 25 years of spannering but the symptopms seem a lot like this:
