Is the Turbo on an ABL face fit to the Manifold or should it have a gasket?????
Methinks its face fit but wanna be sure?????
Discussion Starter · #8 ·
if you mean where the exhaust manifold is bolted on to the turbo (5 bolts) then i do have a gasket here, its not a part you can buy from vw either:eek:
wish id never disturbed this joint to make fitting my exhaust easier during TDi swap
this schematic shows the assembly
If your talking about item 1 on that drawing,thats not the turbo/manifold joint thats the turbo exhaust outlet/downpipe joint.The turbo bolts to the manifold with 3 bolts
