Hi All
I have a 2000 reg 1.9TD - idles and runs sweetly but has just started screeching about 2000rpm. I had a listen around the top of the engine and sounds like it's coming from the vicinity of the turbo.
So far I have re-sealed the inlet manifold gasket (turbo output/below the EGR) and checked the oil supply to the turbo. I can get a finger into it and found a little plat in the turbo shaft - maybe a mm or so.
I can't see any other posts for turbo issues on the ABL engine. Am I on the right track? A local garage suggested the aux belt or the overrun clutch on the alternator. Couldn't hear it down below but then I could be half deaf :(
Any thoughts welcome!
Discussion Starter #2
Fixed it I:
My not-so-deaf son pinpointed it as coming from the exhaust underneath - one of the 3 bolts holding the downpipe to the cat had disappeared!
Quite an impressive noise though!
Full of Cr*p....
Good to get a feedback for a change. T:
Usually the noise if from the inlet side.....something to remember now.
