Hello
My 05 Caravelle went to the garage as a ABS light is on the dash and they checked the codes and said it was "sender 1 for brake presure - G201, electrical fault in circuit breifly ocuuring DTC (01435 108)"
Can anyone tell me if this is simply replacing sensor 1 or the fualt could be in the wiring somewhere, and by the way, which one is sensor 1? the garage only gave me the fault information and i don't have the time or money to go back for them to investigate it more
any help would be great, thanks
Owen
Check to see if you have any brakes lights?
Or if the brake the light switch is stored in any other ECU?
If yes - you need a new brake light switch
if no - check the MVB (measuring blocks) one will be brake pressure sensor should read about 0 then rise when the brake is pressed.
but please give your garage more time other wise it might cost you a lot more in the long run :eek:
