Hi there!
I have recently replaced my T5's passengers side wheel bearing. Ever since then, the abs light comes on and off periodically and sometimes stayes on permanently. Iv'e tried replacing the speed sensor, but still the same. i've checked out the wiring to the pump and all seems ok. Anybody have a solution????? I'm Desperate to sort this out!!!!!
Hi there!
strange when the lights on take it for diagnostic check ,worth a try T:
Mines the same! God only knows why. I was told the only way to sort it was a new ABS pump at a grand total of £1072.00 :(
Claened the sensors on my T4 when i had a similar problem. Sorted.
I'd take wheel off, check any cables/sensors etc. Give them a clean and see if that helps. Cost nothing and may be something as simple as this.
Good Luck.
Guy
