41 - 49 of 49 Posts
Special Rapporteur
Ah ok - so not the full-on lights display. I think if you get the "no communications" fault codes it's game over - otherwise you stand a chance that it will just be a wiring problem...
This is becoming a right PITA now. I have the full disco with no speedo and bouncing/beeping fuel gauge. So far I have checked the rear looms, they were perfect and read 12ish (I cant remember exact voltage) volts. I checked the plugs under the pax seat, they were fine. The fwd loom, when disconnected from the sensors only read a few volts (not usre if this means the fwd loom is U/S?). I need to pop it on VAGCOM again but I think Im looking at an ABS ECU. Ill be throwing it at a garage very soon.
Sorry to hijack Fluffsri but do you know where the cables for the front sensors connect into the main loom? I've got a new OSF ABS loom to fit, the cable is quite long but I've not had a chance to have a look what with the weather etc.
Craig
Craig
No mate, its something I was going to look into. Somewhere on here is a thread and a guy has changed hs, he didnt give exact descrfiption but did mention it doesnt take long.
I will have mine on VAGCOM today so ill see what I have.
Had it on VAGCOM earlier and this is the list
Tuesday,05,January,2016,10:25:00:06461
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
VIN: WV1ZZZ7HZ8H064670 License Plate: T5KWN
Mileage: 161140km-100127mi Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H064670 Mileage: 161140km-100127miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 AH HW: 038 906 016 AH
Component: R4 1,9L EDC 000SG 9875
Revision: --H05--- Serial number: VWZ7Z0G5895387
Coding: 0100031
Shop #: WSC 02736 790 00000
VCID: 5ABFFFDB960644EE5F-513C
1 Fault Found:
005705 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 83
Reset counter: 255
Mileage: 161148 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 AD
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000100
VCID: 74E3B16314A2129E65-5102
2 Faults Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
No fault code found.
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 952 B
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 00413
Shop #: WSC 00001
VCID: 2C536903DC120A5EFD-5120
WV1ZZZ7HZ8H064670 VWZ7Z0G5895387
1 Fault Found:
01316 - ABS Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02736
VCID: 70EBBD7330BA2EBE81-5102
1 Fault Found:
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C11 Komfortgerát 0004
Coding: 00069
Shop #: WSC 02736
VCID: 326F777BFE365CAEB7-4AE6
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: Steuerger
Component: t Beif. antwortet nicht
1 Fault Found:
01312 - Powertrain Data Bus
79-00 - Please Check Fault Codes
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
End-------------------------(Elapsed Time: 06:16)--------------------------
By the way this is an intentional Hi jak! Ive found lots of threads with not a lot of tech info but of lot of non relevant info. Ive added to this thread as the Chekov has written some great posts.
VW T5 campervan -- Had the intermittent failure codes from the ABS in VCDS lite (005705 - Powertrain Data Bus: Missing Message from ABS Controller) P1649 - 000 - - - Intermittent
After trying all the other options-- reseating connectors \looking for faulty earths etc. decided I had nothing to loose by taking ecu off and cutting top cover off, as mentioned in other threads. Nothing was visibly wrong but the pins from the connection plug look to be a push through\small spring lug connections onto circuit board. S previously stated I had nothing to loose so I carefully soldered all the back of the pins where they come through the circuit board.
I've put the van back together and done 50 miles and touch wood all is now OK :) --no faults showing on VCDS, whereas before several ABS faults were always logged even after clearing them and driving a few miles.
So, after trying all other options and if you a reasonably competent at soldering I would suggest it's worth a try.
My update to this thread.
The front ABS sensors connect under the battery tray. Its a proper pain in the to remove and to try to cut and resplice the new cable in.
I replaced the cable and sensor and VAGCOM gave the same fault. At that point I removed the ABS ECU and sent it for testing, you can still drive the van but it wont have ABS (mine hadn't had ABS for months anyway). ECU testing tested the ECU and reported it as unrepairable. When it was returned to me I cut it open and found the biggest of the chips inside had a small burn on it. I bought a new ECU from Banwy and had it fitted, solved everything!
41 - 49 of 49 Posts
