Hello
I have a 2010 T5.1 and got the ABS and TC yellow warning lights up on our holiday down in Cornwall, sometimes go off but mainly on.
I'm home and plugged it in to VCDS, showing fault on rear right sensor, no reading at all when rotating. Not had chance to delve deeper yet but doing my research on here and reading a lot about the wiring corrosion, but then read this is with earlier (pre 2009) T5's is this the case?
Next is, if I test the wire to sensor what voltage should I expect to see?
Any help appreciated on this and I know it's been covered before but the more I read the further I get from where to start.
Where do i start?
cheers
Where do i start?
cheers
