So drove to france did about 100k then on way home abs light poped on.
Next day on vcds said both left and right where electrical faults. So i tested both wires at the rear hubs and got 12v so wiring seems fine. Ordered 2 sensors and then problems started š¤£
Getting them out... My god guessing they been in there nearly 15 years.
Tried all the you tube videos and after they snap. Hot screw lots of penetrate oil. Anyway only way i could get them put in end was hot solder iron and needle nose pliers and a screw driver chipping bit by bit away...
Got them both done went for a test drive and break warning light and abs light on and beeping.
Code came back as
ABS Wheel Speed Sensor Rear Right (G44): Mechanical Malfunction
and same on left
have i broken the wheel baring using solder iron??? Or think its that whats nackered?
Code came back as
and same on left
